schedule in Vmanage graphs
erodrig
hi
i have the problem that the Vmanage graphs showa a different schedule than de Vedges. do i need to define some configuration on the vmanage?
Torbjørn
Your vManage is just configured to use the default timezone(UTC). You can configure vManage to use the same timezone as your WAN-Edges with the following commands:
configure terminal
 system
  clock timezone {your-timezone}
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
erodrig
hi Torbjørn
almost it works... my timezone is UTC-06:00. I configure it, but the schedule graphs show 1 hour less, looks like if the summer time were enabled, is there a way to disable it?
