SD-WAN AMP Integration
rbncarvalho
Hi Guys,
Any of you had any experience using AMP with the SD-WAN Solution?
I've recently been entitled with a Threat Grid Account and since then I'm not able to configure any device that has the security policy with AMP configured.
The error I'm getting is this:
Failed to update configuration - Failed to get AMP api key from threat grid server for deviceId: C1111X-8P-XXXXXX
Even though I have the API Key configured on the SD-WAN Solution.
Here's the configuration on the Security Policy:
policy
 advanced-malware-protection AMP_to_OUT
  file-reputation-cloud-server cloud-isr-asn.eu.amp.cisco.com
  file-reputation-est-server cloud-isr-est.eu.amp.cisco.com
  file-reputation-alert info
  file-analysis-cloud-server isr.api.threatgrid.eu
  file-analysis-file-types pdf ms-exe new-office rtf mdb mscab msole2 wri xlw flv swf
  file-analysis-alert info
  target-vpns matchAllVpn
Any help would be much apprettiated.
Thank you
Best Regards,
Best Regards,
Please rate helpful posts,
Ruben Carvalho CCIE#57952
I am also facing the same issue with integrating Thread grid. Is there any solution or any breakthrough evolved so far?
Best Regards,
S. Vikram Dharmaraja
