SD-WAN and SIP Trunking
I remember that with Viptela SD-WAN that SIP Trunking to an TelCo was not supported or recommended.
Has that this changed?  Solution would be using a mix of ISR4xxx and C8200 as the platforms.
Thanks.
Got Confirmation that terminating SIP Trunks is not supported on SD-WAN routers.  SIP POTS FXO ports are.
