vManage GUI is not Accessible
Amarendra Nayak
vManage# request nms all status
NMS service proxy
Enabled: false
Status: not running
NMS service proxy rate limit
Enabled: false
Status: not running
NMS application server
Enabled: false
Status: not running
NMS configuration database
Enabled: false
Status: not running
NMS coordination server
Enabled: false
Status: not running
NMS messaging server
Enabled: false
Status: not running
NMS statistics database
Enabled: false
Status: not running
NMS data collection agent
Enabled: false
Status: not running
NMS CloudAgent v2
Enabled: false
Status: not running
NMS cloud agent
Enabled: false
Status: not running
NMS SDAVC server
Enabled: false
Status: not running
NMS SDAVC gateway
Enabled: false
Status: not running
vManage Device Data Collector
Enabled: false
Status: not running
NMS OLAP database
Enabled: false
Status: not running
vManage#
vManage# request nms all restart
Found network_error when stopping NMS SDAVC server
Found network_error when stopping NMS CloudAgent v2
Successfully stopped NMS cloud agent
Found network_error when stopping NMS service proxy
Found network_error when stopping NMS application server
Found network_error when stopping NMS messaging server
Successfully stopped NMS coordination server
Found network_error when stopping NMS configuration database
Found network_error when stopping NMS statistics database
Found network_error when stopping vManage Device Data Collector
Found network_error when stopping NMS OLAP database
NMS statistics database configuration setting is currently unavailable
NMS configuration database configuration setting is currently unavailable
NMS coordination server is disabled
NMS messaging server configuration setting is currently unavailable
NMS application server configuration setting is currently unavailable
NMS service proxy configuration setting is currently unavailable
NMS cloud agent is disabled
NMS CloudAgent v2 configuration setting is currently unavailable
NMS OLAP database configuration setting is currently unavailable
vManage Device Data Collector configuration setting is currently unavailable
NMS SDAVC server configuration setting is currently unavailable
vManage#
vManage#
Seeing these errors while restarting. Can anyone of you please help me here?
Did you add the 2nd disk (hdd) for database operations? Below is video based guide from Cisco
https://www.youtube.com/watch?v=CQruni5x8Vk
HTH,
5 Replies 5
did it work before or first time issue? Check for resources , especially for RAM
HTH,
Thanks for your response, Kannan!
It's a first-time issue, I am deploying a new VM in ESXi. The RAM is 32 GB.
HTH,
Actually, I booted the VM without adding the HDD 2, then I added the HDD afterward and rebooted it. Something might have gone wrong because of that, So I was seeing this issue.
Now I again created the VM keeping all these things in mind, It's working fine and GUI is also up!
Thanks !
Glad that it helped. Please, accept answer as correct solution, if it really helped.
HTH,
