SD-WAN device template to cli mode
angel almaras
I have the platform SD-WAN with the version:
To switch this device to CLI mode ¿is it only necessary to detach devices?
if not, can you tell me what process I should follow
Torbjørn
Hello @angel almaras,
That is correct. If you detach the feature templates the device will be put in CLI mode.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
