SD WAN License Purchasing
Melbruki1
Hello im trying to put together a SDWAN solution. from what i understand I need to order the subscription for example DNA-P-10M-E-3Y this will include the entitlement for all the controllers however i still need to attach this to a router.
my question are the following
1.i would like to attach to a vedge cloud device on my esxi, how do i purchase the this vedge cloud device. I looked in the CCW and did not find it there, when i try to download it its says i dont have the entitlement for it?
2. with the subscription noted above how many controllers do i get, say i wanted to have 2 vsmarts for redundancy do i have to buy another license?
3. if i wanted to use 10 vedge devices for my environment do i have to pay for each one of them seperately as i will be using this setup for a lab.
shkhan1
Did you find the answer? I am also facing a similar problem. I have one D-VM-OP-3Y . Does this mean a single instance of vmanage or a single cluster of upto 6 vmanage instances?
Hope you have figured it out by now!
