SD-WAN OMP Peering
RS19
Level 4
Level 4
In my environment I have 2 vSmart controllers. (vSmart-1, vSmart-2)
In cEdge-1, the OMP peer is established only with vSmart-1. No details about peering with vSmart-2.
in cEdge-2. the OMP peer is established with vSmart-1, for vSmart-2, the status is in init-in-gr.
Does the above means for cEdge-1, OMP peering with vSmart-2 the OMP graceful restart timer has expired & it is remvod from the peering.
For cEdge-2., for vSmart-2, it has entered into OMP graceful restart timer. Once the timer expires, the entry will be removed from the entry.
Is my above understandings are right ?
balaji.bandi
Its all depends on the config and template applied to the edge
if you can also post how the diagram looks like, what code running on the device, some output what you seeing is not correct will help for us to understand the issue :
check some information :
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/217479-omp-best-path-selection-peculiarities-an.html
BB
