SD-WAN Question
sel18
Hey everyone,
Please i want to know with the SD-WAN could i balance an tunnel VPN between two operators.
PS: Not the balance of the traffic but the balance of all the tunnel VPN; i mean also did we can create an tunnel VPN and in the case of failed an operator all the tunnel will balance to the other operator !!
thanks in advance.
5 Replies 5
Amr_Younes
Do you mean to have a main and backup path? not load sharing?
@Amr_Younes
yes not the load sharing, i mean all the tunnel could be balancing between two operators !
You can use the preference under the tunnel interface.
So for example main tunnel has a preference of 100 and backup with lower preference (by default it is 0)
inter ge0/0
tunnel-interface
encapsulation ipsec preference 100
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/System-Interface/systems-interfaces-book-xe-sdwan/configure-interfaces.html
Or you can use last resort option where backup tunnel won't form unless main tunnel is down.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/command/sdwan-cr-book/config-cmd.html#wp2241830502
Yashmit
Hello Sel ,
Please correct me if I am wrong , your concern is if one service-provider link (underlay Transport) will goes down then all tunnels will form via other service provider.
Am I right ?
B.R.
Yashu
@Yashmityes that's it all the tunnels could change !
