SD-WAN Validator 20.14 Template issue
dbillon
I'm configuring the SD-WAN Control Components 20.14 for a lab.
I successfully created and attached a device templates with feature templates for the manager and the controller.
I created a vEdge Cloud template for the Validator (vBond). But when I try to enter its interface names (eth0 and ge0/0) in a VPN interface template, I have an error message : " Interface name should start with the suggested names in drop down only".
If a select an equivalent interface name like "GigabitEthernet0/0", I can create the template but then when I attach the template to my device, I get an error message:
[14-May-2024 18:33:43 CEST] Device failed to process request.  Error Message - /vpn/vpn-instance[vpn-id='0']/interface[if-name='GigabitEthernet0/0']/if-name: Interface GigabitEthernet0/0 name len exceeds max allowed - 16
 Error Path -
    /rpc/edit-config/config/viptela-vpn:vpn/viptela-vpn:vpn-instance[viptela-vpn:vpn-id='0']/viptela-vpn:interface[viptela-vpn:if-name='GigabitEthernet0/0']/viptela-vpn:if-name
Am I missing something ?
Thanks, Damien.
5 Replies 5
balaji.bandi
i use in my same LAB -
create this template go to Templates>Feature>vEdge Cloud> VPN> VPN
Interface
Go to Configuration>Templates>Feature>vEdge Cloud>VPN>VPN Interface Ethernet.
this works for me for the vedge.
BB
With 20.14 (new GUI) I got:
  May be an issue with this release...
Looks like the Template is changed on new version - may be need to verify the documentation - may be that should be predefined to use i guess.
may be you have help on the screen GUI to guide you.
BB
riazgul72112
I had the same issue when doing lab on version 20.14.1. However instead of providing the interface in the template, you can provide the variable name for the interface and when you deploy the configuration on device you can provide the value it will accept it.
riazgul72112
In template I was not able to select (ge0/0 the underlay VPN 0 Interface), so i just named it as "vpn0-iNET-underlay-if-name"
when I attached the template and deploy it will ask you for the values against vpn0-iNET-underlay-if-name where you can put any name as you desire according to your router interface naming convention.
