SD-WAN VLAN XLate question
On a Viptela C8200 router running the SD-WAN image bridge two VLANs on an interface?
I  need to bridge together two VLANs on the SD-WAN router.  i know that I can do it if it is in Autonomous mode.  Need to know if it is doable in controller mode.
balaji.bandi
i do not believe that support (not i have explored that feature) - SD-WAN designed for different problems to solve.
by the way what is the use case here ?
also check the documentation :
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/bridging/ios-xe-17/bridging-book-xe/m-bridging-xe-sd-wan.html
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/configure-interfaces.html#c-VPN_Interface_Bridge-12308
BB
