sd-wan vmanage
R Manjunatha
Level 3
Level 3
I am unable to find another hdc 100GB in this list, it's showing only one hdc that is 3GB only ...am using this controller in eve-ng , please let me know what could be the issue
admin connected from 127.0.0.1 using console on vmanage
Available storage devices:
hdc 3GB
1) hdc
Select storage device to use:
Welcome to Viptela CLI
hdc 3GB
1) hdc
Select storage device to use: 1
Would you like to format hdc? (y/n): y
mke2fs 1.43.8 (1-Jan-2018)
Could not open /dev/hdc: No medium found
Thanks, balaji....
6 Replies 6
balaji.bandi
where did you downloaded the qcow2 images ?  or you conerted from Cisco image ?
you should see 2 files in the vManage folder as below (
virtiob.qcow2 will be 100GB
BB
Yes...what is the command for this to create one more file..?
Thanks, balaji....
Let me add on more point. in order to create this additional disk space, we need to go inside the vManage folder. In my case, i am using 19.2.0
Command.
cd /opt/unetlab/addons/qemu/vtmgmt-19.2.0
/opt/qemu/bin/qemu-img create -f qcow2 virtiob.qcow2 100G
cd
/opt/unetlab/wrappers/unl_wrapper -a fixpermissions
Thanks Lehn, The problem was solved.
