sd-wan
aresblade
if I configure sd-wan and i have a disconnected environement , can i have a sort of caching of app data, so that wehn i have my connection back it send the data cached?
Say for example appA has a policy that says send only wehn you have a reliable link, and if you have only a satellite connection wait until a cable connection is available, something like this.
Torbjørn
There are applications/services that can handle intermittent connectivity by caching data and transmitting in batches. I believe you will need to focus on the application side to achieve what you want.
There are no general network solutions that does this as it would require both ends(client and server) of the traffic flow to handle this kind of behavior.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
There is unfortunately no caching solution like what you describe in Viptela SD-WAN.
do you know if it exist in other solutions? or if there is something we can use with viptela? Thanks
Torbjørn
