Hi Community, I am trying to move my SD-WAN to use Configuration-Groups.
most of the stuff I can build with configuration-groups as I had it befor with Device and feature templates.
Burt there is one missing link
In the feature-template of a WAN interface we were able to assign a QOS-map under QOS/ACL tab to the interface (where we defined the queueing stuff, QOS-amp was defined as localized policy)
This is not possible if using configuration groups (I found no way)
So it seems it has to be done in a policy group, where no you can define the Queueing and Marking.
Then this policy group can be assciated with a device, but this fails, because policy-group and centralized policy cannot share the same site.
If I remove the site from the site-list where the centralized policy is assigend, then the policy group can be attached to the device.
BUT in this case I also loose the AAR part of the centralized policy, and in the configuration group we are not able to configure the AAR stuff.
So it seems there is still a missing link to really use configuration groups ??
Any body an idea how to come arround this issue ??
Thx
hUBSERT
