Upgrading Viptela from CLI
Alain Nohra
I am trying to upgrade viptela image from cli because it's not managed by vmanage however i am getting the following error:
vedge# request software install viptela-20.4.1.2-mips64.tar.gz reboot
ERROR: install: Kernel image not found
Note that the MD5sum is checked and passed and the signature suceeded.
balaji.bandi
i have addresssed other post, try upgrade using vManage  ?(why you like to do command level ?)
BB
i have only 1 router No vManage
did you added file to local disk? If yes, use below command:
request software install-image [file-name]
Don't forget to activate after "request software activate now [version]" command.
HTH,
tried same result
