02-14-2024 01:53 AM
Hello Team,
Being new to SDWAN solution, I have deploy Viptela components with 3xvManage, 3xvSmart , 2xvBond , 4xvEdge and 4xCSRv/ISRv on EVE-NG . I want to do configuration backup of all components and I have some questions as mentioned below :-
1. Local Configuration backup on one vManager is enough for cluster backup or do I need to backup all cluster member individually.
2. vManager backup includes vEdges configuration or not. If not It means that need to take backup of every Edges individually.
3. vBond/vSmart Backup will be taken separately . Right?
4. Configuration backup includes CSR certificates or not on all SDWAN components.
5. In case of any restoration of any components do I need repeat Certificate Authentication process again or not.
Thanks in advance for your feedback.
With Regards
Uni
02-14-2024 09:48 AM
Comments inline.
1. Local Configuration backup on one vManager is enough for cluster backup or do I need to backup all cluster member individually. <DF> Backup each vManager configuration.
2. vManager backup includes vEdges configuration or not. If not It means that need to take backup of every Edges individually. <DF> Edges need to be backed up individually. There is an API to backup all configurations from all components in SDWAN. api_url = '/dataservice/template/config/running/' + chassisid
3. vBond/vSmart Backup will be taken separately . Right? <DF> Right.
4. Configuration backup includes CSR certificates or not on all SDWAN components. <DF> Configuration backups does not include certificates.
5. In case of any restoration of any components do I need repeat Certificate Authentication process again or not. <DF> New control components will require a new CSR to generate public/private Key pair to submit for CA to sign.
