vManage-system-ip Vs System-ip
John.lc
Hi  Experts
Is there any difference between vManage-system-ip and System-ip in cEdge. And how to check them by commands?
10 Replies 10
vManage-system-ip
Are you sure this command is correct?
MHM
No, it's not a command.
I know system ip is a ip address of cedge, you could search the vmange-system-ip in vmanage dashboard. I believe it will be shown on vmanage release 20.6 ...
If that case then both same
System-ip in cedge is use to config unquie IP of router via cli
Vmange-system-ip via GUI give unique IP to vmanage.
These IP is unquie and it work as identity of device.
MHM
I don’t think these two addresses are the same, but you mentioned that one is configured in the CLI (system-ip), and the other is assigned to the device (that is, vmanage-system-ip). I am more willing to believe this statement. , but is there any documentation that explains it? I haven't found any relevant instructions so far. I don't know how to check vmanage-system-ip in CLI or GUI. Of course, system-ip is easy to check, whether in GUI or CLI.
svemulap@cisco.com
Think of System-IP as a router-ID. It has to be unique in the network.
Each device will have a unique router-ID.
In the context of SD-WAN, a given device uses this system-IP to reach another node.
You can see the system-IP, via show running-config or show interface command.
The SDWAN design guide is a good source.
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html#SystemIP
HTH.
Yes, system-ip is easy to check, but I want to figure out the difference between it and vmanage-system-ip, how to check them, and what are the differences in their functions. i did't find any info about vmanage-system-ip, but it actually exsit.
John.lc
In the past, you could choose to view vmanage-system-ip here(such as, release 20.3), but you can't see it now. When we query through vmanage-system-ip, we can also query the information corresponding to cEdge.
what do you mean by "vmanage-system-IP"?
HTH,
It could be shown on vmanage dashboard by path “monitor > device”
John.lc
Does anyone else know about this problem?
