01-23-2024 11:08 AM
Hello
i am onboarding a new Cedge. control connections are up but BFD sessions are not coming up. While troubleshooting i noticed Peer IPs for Vmange and Vsmart are from 169.254 range. which is strange and probable cause.
Looking for help in troubleshooting this issue
01-23-2024 11:21 AM
Did you config vmange and vsmart vpn0 correctly?
MHM
01-23-2024 11:36 AM
its only one Cedge having this problem, other cedges were on boarded smoothly. i dont think there is any issue on the Vmanage/Vsmart side
01-23-2024 11:43 AM
Can you check if both vsmart and cedge share same organization-id domain and there is no conflict in Site-ID
MHM
01-23-2024 01:11 PM
share:
show sdwan control connections
show sdwan omp peers
show sdwan omp tlocs
from cedge device
01-23-2024 04:35 PM
You need to provide mode information :
1. what device model , IOS code running on it - other device working same model and same IOS ?
2. did the control connection up and is the device onboarded and you can see in vManage sync and reachable ?
3. is the only issue with BFD ? - how is your cedge path to reach vManange (any firewalls ?)
check below troubleshooting guide :
01-24-2024 01:32 AM
In addition, BFD sessions are between WAN edges (IPSEC Tunnel) - where the data traffic pass. So, there seems to be few things you need to check first. I would start by troubleshooting the control connections between WAN edge router and the controllers. Can check the control connections-history output?
