sdwan issue
chandrakant-dn
Jio airbiber internet is not working in my clients Cisco ISR 1100 4G. Is there any setting to be changed
Can I see cedge router config
MHM
balaji.bandi
This is SD-WAN Issue ? i do not believe so.
basically the router you setup does not connect to Service provider network when you use 4G.
Then you need to troubleshoot - use below configuration guide :
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x/cisco_1100_series_swcfg_chapter_01011.html
or is this 4G connection ok on ISR and you not able to use in SD-WAN environment ?
BB
