Unexpected Traffic Routing Through SD-WAN Router despite AAR Configu
Although we have configured all traffic to route through Private1(SD-WAN Router 1) using AAR, there is still some traffic passing through biz-int. We have built the SD-WAN environment with the configuration shown in the attached image.
On the vSmart, we have implemented the following settings to ensure that all data traffic is routed through Private1 using AAR.
app-route-policy Site01_AAR
  vpn-list VPN3301
   sequence 9999
    action
     count AAR_Sequence_9999
     sla-class SLA_Class_0 preferred-color private1
policy
  loss 100
However, when checking with Zabbix (a network monitoring tool), we observed that there is traffic (about 20Mbps) passing through the WAN(Biz-internet) interface of SD-WAN Router 2.
Our expectation was that all traffic would be routed through the WAN of SD-WAN Router 1.
Do you have any idea why this might be happening? Could the traffic bursts observed in Zabbix be related to this issue?
31 Replies 31
dijix1990
Did you do aar policy for branch and DC? or just for branch? (because aar needs to be aply both sites for traffic between from service side)
for example, I have two AAR policy:
For my Branch
vpn-list VPN12-Voice
sequence 1
match
source-ip 10.10.0.0/16
destination-ip 10.10.232.0/23
action
count aar-voip-cc_-1495326817
backup-sla-preferred-color biz-internet public-internet
sla-class Realtime
no sla-class strict
sla-class preferred-color mpls metro-ethernet
 For DC
sequence 1
match
source-ip 10.10.232.0/23
destination-ip 10.10.0.0/16
action
sla-class Realtime
no sla-class strict
sla-class preferred-color mpls metro-ethernet​
Show sdwan policy <<- since you use counter you can use it to see if your policy seq have count any packet or not
Share here if you can
MHM
Or via Web, Sdwan has troubleshooting features for Aar - device - troubleshooting - Simulate Flows easier way to check policy
Friend I know, one by one this trouble
Troubleshooting is process of checking many items, so one by one let see where is issue
MHM
Thank you for you guys comments!
We configure AAR for both of DC and edge.
And, the current problem is outgoing traffic of edge router. So, AAR of Edge router is related with this.
I gave the show sdwan policy command on SD-WAN Router2 .
SD-WAN-Router-2#show sdwan policy access-list-counters
NAME COUNTER NAME PACKETS BYTES
REMOTE_INET_acl REMOTE-INET_drop 8417 509394
REMOTE-INET_seq6 0 0
REMOTE-INET_seq7 0 0
REMOTE-INET_seq8 745685 73125340
REMOTE-INET_seq9 119876 10351450
REMOTE-INET_accept 0 0
Spoofing_Prefix_drop 0 0
default_action_count 2810460709 727008821743
From_Tunnel_Remark_acl class-default 1457924204 1788895586480
FTR_seq11_Queue0_cm 998596585 203685141373
default_action_count 0 0
SDWAN-Control-Packet_acl vB-packet-counter 249384 15461808
vM-packet-counter 101794782 40757439836
default_action_count 1458851453 1789061762769
other-control-packet-counter 1704341024 302818148717
SD-WAN-Router-2#
SD-WAN-Router-2#show sdwan policy data-pol
You need to see counter name you use in AAR
MHM
@MHM Cisco World
How can i check AAR policy counter?
I checked show sdwan policy data-policy-filter.
I see the counter for my data policy(DP_Sequence_9999), but can not find AAR policy counter(AAR_Sequence_9999) that i configured.
SD-WAN-Router-2#show sdwan policy data-policy-filter
data-policy-filter VPN3301_Site30307005_DP
data-policy-vpnlist VPN3301
data-policy-counter DP_Sequence_9999
packets 211731396
bytes 208800210140
data-policy-counter default_action_count
packets 0
bytes 0
SD-WAN-Router-2#
@MHM Cisco World
Oh, I got the counter for AAR.
SD-WAN-Router-2#show sdwan policy app-route-policy-filter
NAME NAME COUNTER NAME PACKETS BYTES
VPN3301_Site30307005_AAR VPN3301 AAR_Sequence_9999 280130664 295674158592
SD-WAN-Router-2#
Only "AAR_Sequence_9999" counter is up, and no counter is up for default_action_count..
So you aar policy seems correct, and it applied both to dc and branches and both from service side only, is it correct?, and as I understood you have data policy for same vpn, can you share config?
Oh and can you do Simulate flow (monitor - devices - choose device - troubleshooting - Simulate flow) for traffic from vpn 3301 from both edge routers?
@dijix1990
Yes, correct.
data policy configuration is the following.
SD-WAN-Router2#show sdwan policy from-vsmart
from-vsmart sla-class SLA_Class_0
 loss 100
from-vsmart data-policy VPN3301_Site30307005_DP
 direction from-service
 vpn-list VPN3301
  sequence 9999
   action accept
    count  DP_Sequence_9999
    cflowd
    log
  default-action accept
from-vsmart cflowd-template VPN3301_netflow
 flow-active-timeout    600
 flow-inactive-timeout  60
 template-refresh       60
 flow-sampling-interval 1000
 protocol               ipv4
 customized-ipv4-record-fields
  no collect-tos
  no collect-dscp-output
 collector vpn 3301 address 10.122.242.243 port 2055 transport transport_udp
from-vsmart app-route-policy VPN3301_Site30307005_AAR
 vpn-list VPN3301
  sequence 9999
   action
    no sla-class strict
    sla-class preferred-color private1
from-vsmart lists vpn-list VPN3301
 vpn 3301
SD-WAN-Router2#
Yes, I can, I did simulation flow from both SD-WAN Router1 and 2 to the LAN IP address (VPN3301) of SD-WAN ROuter in another site.
SD-WAN ROuter 1
SD-WAN Router2
The traffic goes through private1 in both SD-WAN Router.
Good! simulate traffic shows us that everything correct. I thought that data policy overwrite or policy (if you have the same aar policy and data policy and colors there doesn't match beetwen them than data policy has priority by colors from data policy)
Maybe you have another vpn's which can goes via biz-int?
Try to watch what traffic goes via biz-int - for example via command sh flow monitor sdwan_flow_monitor cache format table | i your biz-internet interface
Oh For my experience AAR + Data Policy with feature pkt-dup (loss correction) work don't correctly (Just to know)
Thank you for your quick response, appreciate!
There are no info related with traffic..
"show flow monitor sdwan_flow_monitor cache format table" this command is for vEdge?
My device is IOS-XE 17.6.5 cEdge.
SD-WAN-Router2#show flow monitor sdwan_flow_monitor cache format table
  Cache type:                               Normal (Platform cache)
  Cache size:                                80000
  Current entries:                               0
  High Watermark:                               75
  Flows added:                              295706
  Flows aged:                               295706
    - Active timeout      (    60 secs)         23
    - Inactive timeout    (    10 secs)     295683
There are no cache entries to display.
SD-WAN-Router2#
We don't have another VPN except for 3301.
Yes, command for cEdges (ios-xe)
I saw you have configuration for your collector
cflowd-template
Can you check in local policy for these routers if netflow was enabled for checkbox, I think because of it you don't see netflow in cli
Where is the checkbox in GUI? and Do you know what the configuration for CLI?
My netflow configuration for this router is the following.
Router
flow exporter sdwan_flow_exporter_0
 description export flow and application visibility records to vManage
 destination local sdwan
 mtu 1280
 transport udp 5458
 export-protocol ipfix
 option drop-cause-table
flow exporter sdwan_flow_exporter_1
 description export flow records to collector
 destination 10.122.242.243 vrf 3301
 mtu 1280
 transport udp 2055
 template data timeout 60
 option interface-table timeout 60
 option sampler-table timeout 60
 option application-table timeout 60
 option application-attributes timeout 60
 option tunnel-tloc-table timeout 60
 description monitor flows for vManage and external collectors
 cache timeout inactive 10
 cache timeout active 60
 cache entries 80000
 record sdwan_flow_record-002
sampler sdwan_flow_sampler
 mode random 1 out-of 1000
ip visibility global flow monitor sdwan_flow_monitor sampler sdwan_flow_sampler input
ip visibility policy flow monitor sdwan_flow_monitor sampler sdwan_flow_sampler input
vSmart
 site-list VPN3301_Site30307005
  control-policy VPN3301_Site30307005_control_in in
  control-policy VPN3301_Site30307005_control_out out
  data-policy VPN3301_Site30307005_DP from-service
  template-refresh       60
  vpn-list VPN3301
   sequence 9999
    action accept
     cflowd
     log
