SDWAN lab
reaven
I have been playing with sdwan in eve-ng with the topology below. I already bring up the tunnels and can see both sites up to vpn0  from each other. still getting use to and practicing with templates but i really  having difficulties in how to send the service vpn through the overlay, for ex. connecting site 300 service vpn 10 with site 200 service vpn 10
10 Replies 10
osdesent
Hi!
Can you share the next outputs from both edges?
#show control connections
#show control local properties
#show bfd sessions
#show omp peers
#show omp tlocs
#show omp routes
#show bfd tloc-summary-list
Oscar Desentis
Customer Success Specialist (SD-WAN)
Well I was able to do it with an extranet policy in vsmart but is this the correct way ?
policy
 lists
  vpn-list client_vpn
   vpn 10
  vpn-list transport_vpn
   vpn 0
  site-list all_sites
   site-id 100
   site-id 200
   site-id 300
 control-policy extranet
  sequence 10
   match route
    vpn-list client_vpn
   action accept
    export-to
  sequence 20
   match route
   action accept
    export-to
     vpn-list client_vpn
  default-action accept
apply-policy
 site-list all_sites
  control-policy extranet in
this is the output but the policy is in place already
 show omp peers
R -> routes received
I -> routes installed
S -> routes sent
                         DOMAIN    OVERLAY   SITE
PEER             TYPE    ID        ID        ID        STATE    UPTIME           R/I/S
1.1.1.2          vsmart  1         1         100       up       1:22:02:26       3/1/1
        PEER                                          PEER                                          CONTROLLER
PEER    PEER PEER            SITE       DOMAIN PEER                                    PRIV  PEER                                    PUB                                           GROUP
TYPE    PROT SYSTEM IP       ID         ID     PRIVATE IP                              PORT  PUBLIC IP                               PORT  LOCAL COLOR     PROXY STATE UPTIME      ID
vsmart  dtls 1.1.1.2         100        1      10.10.1.7                               12446 10.10.1.7                               12446 public-internet No    up     0:22:31:14  0
vbond   dtls 0.0.0.0         0          0      10.10.1.6                               12346 10.10.1.6                               12346 public-internet -     up     0:22:31:32  0
vmanage dtls 1.1.1.1         100        0      10.10.1.5                               12446 10.10.1.5                               12446 public-internet No    up     0:22:31:32  0
show bfd sessions
                                      SOURCE TLOC      REMOTE TLOC                                      DST PUBLIC                      DST PUBLIC         DETECT      TX
SYSTEM IP        SITE ID  STATE       COLOR            COLOR            SOURCE IP                       IP                              PORT        ENCAP  MULTIPLIER  INTERVAL(msec) UPTIME          TRANSITIONS
3.1.1.1          300      up          public-internet  public-internet  10.10.10.6                      10.10.1.8                       12346       ipsec  7           1000           0:22:24:58      0
show omp routes
Code:
C   -> chosen
I   -> installed
Red -> redistributed
Rej -> rejected
L   -> looped
R   -> resolved
S   -> stale
Ext -> extranet
Inv -> invalid
Stg -> staged
IA  -> On-demand inactive
U   -> TLOC unresolved
                                            PATH                      ATTRIBUTE
VPN    PREFIX              FROM PEER        ID     LABEL    STATUS    TYPE       TLOC IP          COLOR            ENCAP  PREFERENCE
0      10.22.1.0/24        1.1.1.2          3      1006     C,R       installed  2.1.1.1          public-internet  ipsec  -
0      10.40.40.0/24       1.1.1.2          4      1003     C,R       installed  3.1.1.1          public-internet  ipsec  -
10     10.22.1.0/24        0.0.0.0          69     1006     C,Red,R   installed  2.1.1.1          public-internet  ipsec  -
10     10.40.40.0/24       1.1.1.2          2      1003     C,I,R     installed  3.1.1.1          public-internet  ipsec  -
By default whenever there's no policy SD-WAN creates a full mesh fabric between all edges. Now your 2 sites have the same VPN 10 so there's no need to do route leaking with that inbound control policy. Plase remove the policy and gather the same outputs.
Oscar Desentis
ok, there you go
vsmart  dtls 1.1.1.2         100        1      10.10.1.7                               12446 10.10.1.7                               12446 public-internet No    up     1:00:31:11  0
vbond   dtls 0.0.0.0         0          0      10.10.1.6                               12346 10.10.1.6                               12346 public-internet -     up     1:00:31:30  0
12446 public-internet No up 1:00:31:30 0
 show control local-properties
personality                       vedge
sp-organization-name              MSI
root-ca-chain-status              Installed
certificate-status                Installed
certificate-validity              Valid
certificate-not-valid-before      Jan 11 15:14:39 2021 GMT
certificate-not-valid-after       Jan 09 15:14:39 2031 GMT
dns-name                          10.10.1.6
site-id                           200
domain-id                         1
protocol                          dtls
tls-port                          0
system-ip                         2.1.1.1
chassis-num/unique-id             553dd379-f093-2c2d-405d-83555f250481
serial-num                        EA45ED56
subject-serial-num                N/A
token                             Invalid
keygen-interval                   1:00:00:00
retry-interval                    0:00:00:18
no-activity-exp-interval          0:00:00:20
dns-cache-ttl                     0:00:02:00
port-hopped                       TRUE
time-since-last-port-hop          1:00:32:22
pairwise-keying                   Disabled
embargo-check                     success
cdb-locked                        false
number-vbond-peers                1
INDEX   IP                                      PORT
0       10.10.1.6                               12346
number-active-wan-interfaces      1
 NAT TYPE: E -- indicates End-point independent mapping
           A -- indicates Address-port dependent mapping
           N -- indicates Not learned
           Note: Requires minimum two vbonds to learn the NAT type
        RESTRICT/          LAST                          VM
                         PUBLIC          PUBLIC PRIVATE         PRIVATE                                 PRIVATE                              MAX     CONTROL/           LAST         SPI TIME    NAT  CON
INTERFACE                IPv4            PORT   IPv4            IPv6                                    PORT     VS/VM COLOR           STATE CNTRL   STUN        LR/LB  CONNECTION   REMAINING   TYPE PRF
ge0/0                    10.10.10.6      12386  10.10.10.6      ::                                      12386    1/1  public-internet  up     2      no/yes/no   No/No  0:00:00:08   0:11:27:37  N    5
 show bfd sessions
3.1.1.1          300      up          public-internet  public-internet  10.10.10.6                      10.10.1.8                       12346       ipsec  7           1000           1:00:25:36      0
 show omp peers
S -> routes sent
                         DOMAIN    OVERLAY   SITE
1.1.1.2          vsmart  1         1         100       up       2:00:05:51       1/1/1
show omp tlocs
C   -> chosen
I   -> installed
Rej -> rejected
L   -> looped
R   -> resolved
S   -> stale
Ext -> extranet
Stg -> staged
Inv -> invalid
        PUBLIC           PRIVATE
ADDRESS        PSEUDO                   PUBLIC                   PRIVATE  PUBLIC  IPV6    PRIVATE  IPV6     BFD
FAMILY   TLOC IP          COLOR            ENCAP  FROM PEER        STATUS    KEY     PUBLIC IP        PORT    PRIVATE IP       PORT     IPV6    PORT    IPV6     PORT     STATUS
ipv4     2.1.1.1          public-internet  ipsec  0.0.0.0          C,Red,R   1       10.10.10.6       12386   10.10.10.6       12386    ::      0       ::       0        up
         3.1.1.1          public-internet  ipsec  1.1.1.2          C,I,R     1       10.10.1.8        12346   10.10.1.8        12346    ::      0       ::       0        up
 show omp routes
Code:
C   -> chosen
I   -> installed
Rej -> rejected
L   -> looped
R   -> resolved
S   -> stale
Ext -> extranet
Inv -> invalid
Stg -> staged
                                            PATH                      ATTRIBUTE
IF            SESSIONS  SESSIONS  SESSIONS
NAME   ENCAP  TOTAL     UP        FLAP
ge0/0  ipsec  1         1         4
I case see a couple of things here...
From the output below that the edge 2.1.1.1 has an IPsec tunnel UP with edge 3.1.1.1, so here we can assume that there's data plane active
show bfd sessions
Can you gather the same outputs from the other edge?
Oscar Desentis
yes, but weirdly enough after removing the policy from vsmart I still have access between sites.  Maybe the policy insert routes and leave it there even when I already removed the policy I even restarted the vsmart and vEdges ?
vsmart  dtls 1.1.1.2         100        1      10.10.1.7                               12346 10.10.1.7                               12346 public-internet No    up     0:00:31:37  0
vbond   dtls 0.0.0.0         0          0      10.10.1.6                               12346 10.10.1.6                               12346 public-internet -     up     0:00:51:04  0
vmanage dtls 1.1.1.1         100        0      10.10.1.5                               12346 10.10.1.5                               12346 public-internet No    up     0:00:51:03  0
personality                       vedge
certificate-not-valid-before      Jan 12 21:04:18 2021 GMT
certificate-not-valid-after       Jan 10 21:04:18 2031 GMT
dns-name                          10.10.1.6
site-id                           300
domain-id                         1
protocol                          dtls
tls-port                          0
system-ip                         3.1.1.1
chassis-num/unique-id             4bcae5f0-fd3d-d801-4065-602863ccbf93
serial-num                        EDF456A2
token                             Invalid
port-hopped                       TRUE
time-since-last-port-hop          0:00:51:24
cdb-locked                        false
INDEX   IP                                      PORT
0       10.10.1.6                               12346
        RESTRICT/          LAST                          VM
ge0/0                    10.10.1.8       12366  10.10.1.8       ::                                      12366    1/1  public-internet  up     2      no/yes/no   No/No  0:00:00:16   0:11:28:01  N    5
 show bfd sessions
2.1.1.1          200      up          public-internet  public-internet  10.10.1.8                       10.10.10.6                      12346       ipsec  7           1000           0:00:50:17      0
show omp peers
S -> routes sent
                         DOMAIN    OVERLAY   SITE
1.1.1.2          vsmart  1         1         100       up       0:00:32:43       1/1/1
 show omp tloc
Possible completions:
  tloc-paths   Display TLOC paths
  tlocs        Display TLOCs
vEdge-HQ# show omp tlocs
C   -> chosen
I   -> installed
Rej -> rejected
L   -> looped
R   -> resolved
S   -> stale
Ext -> extranet
Stg -> staged
Inv -> invalid
        PUBLIC           PRIVATE
ipv4     2.1.1.1          public-internet  ipsec  1.1.1.2          C,I,R     1       10.10.10.6       12346   10.10.10.6       12346    ::      0       ::       0        up
         3.1.1.1          public-internet  ipsec  0.0.0.0          C,Red,R   1       10.10.1.8        12366   10.10.1.8        12366    ::      0       ::       0        up
 show omp routes
Code:
C   -> chosen
I   -> installed
Rej -> rejected
L   -> looped
R   -> resolved
S   -> stale
Ext -> extranet
Inv -> invalid
Stg -> staged
                                            PATH                      ATTRIBUTE
10     10.22.1.0/24        1.1.1.2          1      1003     C,I,R     installed  2.1.1.1          public-internet  ipsec  -
10     10.40.40.0/24       0.0.0.0          69     1003     C,Red,R   installed  3.1.1.1          public-internet  ipsec  -
ge0/0  ipsec  1         1         2
Can you gather these outputs on both edges?
#show ip route vpn 10
or #show ip route vrf 10 in case you are using cEdges
Oscar Desentis
since there is no route leak, i am suppose to get to each other from vpn 10  ?
Ex.  ping 10.40.40.x vpn 10
site 200
 show ip routes vpn 10
Codes Proto-sub-type:
  IA -> ospf-intra-area, IE -> ospf-inter-area,
  E1 -> ospf-external1, E2 -> ospf-external2,
  N1 -> ospf-nssa-external1, N2 -> ospf-nssa-external2,
  e -> bgp-external, i -> bgp-internal
Codes Status flags:
  F -> fib, S -> selected, I -> inactive,
  B -> blackhole, R -> recursive, L -> import
                                            PROTOCOL  NEXTHOP     NEXTHOP          NEXTHOP
VPN    PREFIX              PROTOCOL         SUB TYPE  IF NAME     ADDR             VPN      TLOC IP          COLOR            ENCAP  STATUS
10     10.22.1.0/24        connected        -         ge0/1       -                -        -                -                -      F,S
10     10.40.40.0/24       omp              -         -           -                -        3.1.1.1          default          ipsec  F,S
site 300
Codes Status flags:
10     10.22.1.0/24        omp              -         -           -                -        2.1.1.1          default          ipsec  F,S
10     10.40.40.0/24       connected        -         ge0/1       -                -        -                -                -      F,S
Correct with the current outputs you should be able to reach one site from the other since you have an IPsec tunnel UP between both sites and both sides in the service VPN 10 have a correct route.
Try this from site 200
ping vpn 10 10.40.40.X (host)
Oscar Desentis
sahrana
Hi Team
As I have SD-WAN LAB setup. I have issue Alarms, I am not getting BFD_SITE_UP and BDF_SITE_DOWN alarm in vManage for vEDGE devices.
all the control connection is showing UP.
please support.
