SDWAN NAT's Via CLI
Tim_J_RC
Hi, I am working on migrating my legacy edge device to SDWAN.   Our edge devices have a bunch of different NAT's.   Static NAT outside source, Static NAT inside source,  PAT's, NAT Pools, and a few others that work well with CI, however seem impossible with SDWAN VMANAGE feature templates and data policies.
I would like to do these NAT's via CLI addon template, however I have had no success getting this to work.   I am currently using a C8000v image in EVE-NG to develop it.   Has anyone had success with getting NAT's to work via CLI?    I think some of the prblems I have is identifying my inside and outside interface.   My service side VPN201 is assigned an interface which I can set at 'ip nat inside' with no problems, however , what I think my outside interface would be is my Tunnel4 which in is VPN 0.    Any ideas?   I am really trying to keep this simple for my deployment teams.
There are two method to config NAT'
I will share doc. Help you in config.
If I forget please make me remember.
MHM
I'd appreciate any help.
Can you post relevant config? Your outside interface should be your TLOC interface, not your tunnel interface.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
