SDWAN Router Switch Combo
JTaylor32281
I am looking for a router and switch combo that supports SDWAN. Although space is an issue a full size router will be to big. Currently we are using a 1841 but would like to change over to SDWAN. The amount of ports needed for the switch is minimal 6-8 would be just fine.
Any ideas?
omz
Is it Viptela SDWAN or Meraki SDWAN?
Is it Corporate or Home network?
Viptela vEdge and Meraki MX have small form factor with 4-10/12 ports
We use both Viptela and Meraki.
Its corporate.
Just be aware that while switchport modules are available for cEdge routers, I have come across issues with the NIM-ES2 where spanning tree is not supported until cEdge v17.2.
Simon Ko
C1111X-8P has 8 port switch with two WAN ports.
ISR3321 has 8 ports
