11-20-2021 07:40 PM - edited 11-20-2021 07:41 PM
Hi friends,
can you please help me to understand the Tunnel concept use in the SDWAN.
1.What is the tunnel source address ? (is it physical IP address bound with the tunnel)
2.What is the tunnel IP address ? (is it the system IP)
3.WAN-Edge device use same tunnel interface for control connection (DTLS/TLS) and Data plane (IPsec). How Router undestand which traffic should encapsulate using DTLS and which traffic should encapsulate using IPsec ?
4.In DTLS connection will the wan-Edge device encapsulate encrypted packet with new IP header ?
Thank you verymuch for your support
11-20-2021 09:47 PM
11-20-2021 10:27 PM - edited 11-20-2021 11:28 PM
Thank you very much for the reply.Please help me to confirm following understandings.
so ,
in the point 4 , also the controller DTLS connection will use tunnel mode and in this case also New IP header IP address and original IP header IP address is equal to the physical interface IP address.
