SDWAN vs. SDN
Michael1975
My company uses SD-WAN, my school offers a class on SDN. I know they are not the same thing, my question is if I learn about SDN, will some of that knowledge help me understand SD-WAN?
SDN is generic concept which is Software Defined Network.
Original concept is decouple control and data plane. If you learn any generic information about SDN, then you will have understanding how it differs from classic networking. Although this information will be helpful, but will not provide direct information for SD-WAN.
Indeed, SD-WAN technology is type of SDN for WAN. Different vendors have different solutions, concept, architecture. In the final, all can be managed via programmable options and have built-in automation options > which is reason it is called "software defined".
HTH,
Torbjørn
Software Defined Networking is a concept, of which SD-WAN is an example of. You are likely to be better prepared to learn an SD-WAN solution by learning about SDN. If these subjects interest you I can recommend watching this video by NetworkChuck: https://www.youtube.com/watch?v=isMnWZqAh0k
These pages might also be interesting to you:
The Cisco Learning Network is also a good place to both learn and interact with others who are on the same path as you: https://learningnetwork.cisco.com/
Good luck with your studies!
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Thanks for your input. It was very helpful.
HTH,
Michael1975
Thank you for your  answer. You were very helpful.
