Serial number vManage
Ciro G Mele
I have to pass the serial to the tac, use this command in vManage, is this the correct information or does anyone remember which command by cli, catalyst manager or both I can collect this information.
Thank you very much for your help
Regards.
Ciro Gustavo Mele.
5 Replies 5
less probably TAC asks serial of certificate of vmanage. What is purpose and for what TAC asked for "serial"?
HTH,
Hi Kanan,
What is the command via cli or through CatManager to know the serial, do you remember it?
Thank you.
Ciro Gustavo Mele.
Are you attempting to open a TAC case, or is this part of a troubleshooting step? If it is the latter you can request to perform this through a webex session with the TAC engineer.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Thank you.
Ciro Gustavo Mele.
HI good morning,
They inform me that this is the correct command that I wrote above to know the serial.
Thank you very much for your interest.
Regards.
Ciro Gustavo Mele.
