vpn routing on FTD
welmasdoo
right now i have mostly everything working, however, one thing we are having issues with is people on our VPN can not connect to a hosted solution.
previously they were able to do so and to our knowledge our provider has not done anything to the other FTD.
i added it to the split tunnel acl, added a static route to push to that FTD device on our firewall, matching anything going to that IP if it hits to pass to the inside of the other FTD device. still nothing!
any thoughts? i may do a static route to test on my local machine.
Sorry
Can you more elaborate
You tav this post with sdwan
So are vpn is ipsec/gre of sdwan?
Do you config sdwan service to push fw to vsmart?
Or this case is other?
MHM
