SLA Class - strict - AAR
ChrisNewnham_
I have a question.
If configuring an AAR policy, and you set the SLA Class to strict with a preferred colour, does that render the SLA class performance moot, as even if the SLA is breached, it will still only use the "strict" colour?
Thanks!
2 Accepted Solutions
balaji.bandi
If the Preferred route not available, then if other SLA matches it uses that path - again it all depends how this was configured on the policy - better look below example : (for understanding)
Configure Application-Aware Routing Using CLIs
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/policies/ios-xe-17/policies-book-xe/application-aware-routing.html#c_Application_Aware_Routing_Policy_Configuration_Example_12237.xml
Good video explanation :
https://www.youtube.com/watch?v=FbLagRvX04s
BB
preferred color + strict = if there is no path that meets SLA using preferred color > then traffic is drop
HTH,
balaji.bandi
BB
HTH,
ChrisNewnham_
Thanks - much appreciated!
