SNMP OID value for monitoring CPU & memory usage of vEdge 1000
kay.kang
I'm trying to monitor CPU & Memory usage with our vEdge 1000 SD-WAN routers by adding OID values to our SNMP tool.
What are OID values can I add for monitoring each CPU & Memory usage?
svemulap@cisco.com
Hi Kay.Kang -
Plesse check out: https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/snmp/snmp-book/snmp-book_2.html
MIB Download links are at the bottom of the above link.
Hope it helps.
