SOLVED - Cisco ISR routers and Zscaler integration - GRE and IPsec
Captain HoOmi
Hi everyone,
Does Cisco SD-WAN ( Viptela) ISR 4k routers support GRE or IPsec tunnel to Zscaler?  Is it true that GRE tunnels to Zscaler is not yet supported on the WAN side of the ISRs?
Viptela is actually listed on zScaler website: https://www.zscaler.com/solutions/partners/cisco-sd-wan
But it says vEdge routers and not ISR.
** Please rate this post or accept the solution if it helped! :) **
rbncarvalho
Please read this post below which has the information that you want.
https://community.cisco.com/t5/sd-wan/ipsec-interface-not-available-from-vpn0/m-p/3928722
Best Regards,
Please rate helpful posts,
Ruben Carvalho CCIE#57952
rbncarvalho
Best Regards,
