SSH not working after activating NAT
AminRamadan
SSH service is activated on vpn 0 under interface ge0/0. The SSH stopped working after I activated the NAT on the same interface!. Does anyone know why?
thank you
balaji.bandi
have you tried other Transport interface ?
Best Practices for Configuring NAT Port Forwarding
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/policies/vedge/policies-book/vEdge-as-NAT-device.html
BB
Yes, I tried to connect via SSH to other transport inteface and it worked. Moreover, the ssh works fins when i de-activated the NAT on int ge0/0. So the problem in NAT.
self-generated packet passes NAT, however if it is initiated from remote, should not make problem.
Could you share what is your NAT config? Also from : show run | sec nat (if it is ios xe)
HTH,
husseino
sorry posted by mistake
