Template locked
pp490a001
I was trying to edit device template for multiple devices, while I was crosschecking the new configs with existing, vManage timed out and logged out my session.
Now when I try to edit the template again, I get following message:
Template locked in edit mode.: Template is locked by user: since:2019-12-11 18:46:39,218
How can I clear the lock?
Will it be cleared by itself?
HashamM
you can use the API call to clear the stuck process for template push
https://<vmanage-ip>/dataservice/device/action/status/tasks
Find the process id and then clear it
https://<vmanage-ip>/dataservice/device/action/status/tasks/clean?processId=<Process-id>
12 Replies 12
HashamM
This didn't work for me - I have no processes running but still get the msg?
Not for me either. I have vManage verion 18.4.4 and have no task running but still get the message.
Yeah I gave up,b just copied the locked feature templates and moved the device templates over to the new ones and trashed the old ones.
Have hit this in production as well as lab so I think there's some niche scenario with your browser and not logging out properly
Hi  Johann Lo,
When template gets locked, then in this case you just have to logged out from vManage and login again or you can wait for 60 second to expire the session.
There is nothing you can do about it. I have faced many time with the same issue.
Rohit Raj
This worked for me.
Thanks a lot for sharing
RohitRaj03827
You can either wait for the session to expire or just logged out from vmanage and refresh the web url and login again. It will automatically clear the session. I have faced many time with the template locked issue. By default timer is 60 second.
If this post has answered your query, please mark as a solve and hit helpful button.
Rohit Raj
Rohit Raj
This time waiting for 60 seconds doesn't help. Rebooting the vManage doesn't help either. It is still locked. Someting weird is going on in vManage in general. Loading feature template page takes ages. I opened TAC case about this.
Hi ,
Has TAC Reverted on this on how to remove the Lock ?
Rgds,
You may need a TAC case. But can check the possible reason by following below steps
Step 1 : Login to vManage
Step 2 : Go to https://vManage_IP/logsettings.html
Step 3 :  Enable viptela.enable.query.builder.log
Step 4 : Recreate the issue
Step 5 : Check logs in vmanage-server.log
If you see similar to below logs, then get TAC's assistance to clear the lock
21-Apr-2019 06:08:29,309 UTC INFO  [EMSUROVMA1] [Neo4JDBQueryBuilder] (default task-505) |default| Executing builtQuery :MATCH (n:vmanagedbTEMPLATELOCKNODE)  WHERE (n.`templateId` in ['7332ae09-c00e-4038-9197-ee2609a0f0c3']) RETURN  n._rid as _rid, id(n) as _id,  n.`userSessionUserName` as `userSessionUserName` ,n.`startTime` as `startTime` , calledBy : com.viptela.vmanage.server.deviceconfig.template.lock.DeviceTemplateLock.isTemplateLocked:75
21-Apr-2019 06:08:29,312 UTC INFO  [EMSUROVMA1] [DeviceTemplateLock] (default task-505) |default| Template lock is present for templateId:7332ae09-c00e-4038-9197-ee2609a0f0c3
21-Apr-2019 06:08:29,312 UTC ERROR [EMSUROVMA1] [RestfulDefaultExceptionMapper] (default task-505) |default| Exception while processing request : com.viptela.vmanage.server.deviceconfig.template.TemplateException: Template is locked by user:afaragya since:2019-04-21 04:31:28,172
21-Apr-2019 06:08:29,306 UTC INFO  [EMSUROVMA1] [Neo4JDBQueryBuilder] (default task-505) |default| Executing builtQuery :MATCH (n:vmanagedbTEMPLATELOCKNODE)  WHERE (n.`sessionId` = '136QKqtWTU3_upOV3NvzqWwiRbqhKpIM3Jbd1MnT') RETURN  n, id(n) as _id, calledBy : com.viptela.vmanage.server.deviceconfig.template.lock.TemplateLock.isUserAlreadyEditing:153
Hi Hasham,
Thanks for your response . Is there any way to remove the Lock or some doc for the same ?  I have done a temporary Workaround but wanted to know the solution on how to unlock/release a Locked Template as will be very useful in Production Scenarios. Currently i do not have TAC access so unable to raise a Case. Any help will be appreciated . Thanks.
Rgds,
Saji Samuel
I found a workaround for this. If your template is locked in edit mode while editing as the user xxxx, log out user xxxx and log in using admin and try to edit. Then vManage allows you to edit.
