TLOC and NIM in C8300
2 Quick questions - in a Cisco C8300 can a NIM module be used for TLOC?  Also, can you LAG two TLOC Ethernet interfaces?
Thank  you!!
inderdeeps
Level 4
Level 4
Cisco C8300 can a NIM module be used for TLOC, when you sat TLOC, is that for the transport side interface, the answer is Yes.
Check your answer there below
Cisco Catalyst 8300 Series Edge Platforms FAQ - Cisco
Inderdeep Singh
www.thenetworkdna.com
***RATE MY RESPONSE IF YOU LIKE MY REPLY****
