06-04-2025 01:53 AM
I have configured 2 WAN Edge routers as a dual router site, each has a dedicated WAN circuit. R1 has public-internet and R2 has biz-internet. I have also configured a tloc extension between the two so that R1 can use R2 biz-internet transport and R2 can use R1 public-internet transport.
When I refresh the view in Manager not all of the control connections are 100% forming over the local colour and the tloc extension colour, some of the routers have 100% control connections over both and a couple don't. If I refresh again the ones that didn't have 100% control connections now have them and the ones that did now don't. This changes each time I refresh.
The fact that control connections form over both local and telc extension paths makes me think that the config is correct, but why would I be seeing this behaviour and how do I fix it?
The BFD sessions are also not 100% and keep changing on refresh.
Just for more info, I'm using Configuration Groups.
Solved! Go to Solution.
06-05-2025 04:56 AM
Hi, Richard.
As far as I know, The BFDs (include TLOC ext) dont up fully If TLOC ext configs are wrong.
Please refer to this picture, and modify the static routing, tloc ext configuration.
https://www.networkacademy.io/ccie-enterprise/sdwan/tloc-extension
Thank you.
Please remark this as a solution If this is helpful.
06-04-2025 02:08 AM
06-05-2025 04:56 AM
Hi, Richard.
Thank you.
06-05-2025 05:01 AM
Hi Jeongjun
Thanks for taking the time to reply.
I worked out what the issue was, I had forgotten to bond the WAN interface to the TLOC extension interface on both routers. Once I fixed that each router was able to create control, IPSEC and BFD connections out of both the local WAN and TLOC extension interfaces.
Rick
06-05-2025 05:08 AM
Good to hear !
Hope you have a good day !
