Tunnel and SDWAN interface as Logical Loopback Interface
abdul.qadir5001
We want to use any logical interface like loopback interface (Loopback1) instead of physical interface (TenGigabitEthernet0/0/3) for below tunnel and sdwan configurations on Cisco SDWAN router C-8500 . The reason is that interface TenGigabitEthernet0/0/3 is towards ISP and we want to avoid frequent up/down of this physical interface. What is the effect of this change. Is it recommended or not. Please need your support
interface Tunnel1
 ip unnumbered TenGigabitEthernet0/0/3
 tunnel source TenGigabitEthernet0/0/3
 tunnel mode sdwan
interface Tunnel1
 ip unnumbered Loopback1
 tunnel source Loopback1
 tunnel mode sdwan
sdwan
tunnel-interface
encapsulation ipsec
sdwan
 interface Loopback1
tunnel-interface
encapsulation ipsec
interface Loopback1
ip address 2.2.2.2 255.255.255.255
end
how will you avoid up/down event if it will happen in any case (based on my understanding you have frequent flaps).
You will lose physical port which affects transport for loopback for control and data path (bfd) will flap.
HTH,
