Using vlan interface as uplink on the vpn 0
dijix1990
Can I use vlan interface as WAN on the vpn0?
On this list I can see name - Vlan, but when I choose "Vlan" vManage says to me - Invalid Interface Name. Must not include 'vlan'
VPN Interface Ethernet should not support VLAN. For VLAN interface (so called SVI) you should choose separate type of interface template "VPN Inteface SVI". Below is details about bridging.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/bridging/ios-xe-17/bridging-book-xe/m-bridging-xe-sd-wan.html
HTH,
HTH,
