vAnalytics Error - An error occurred while attempting to navigate to
Hello.
I'm running SD-WAN fabric on EVE-NG
When I try to open vAnalytics on vManage, error occurs.
How can I solve this problem ?
Hi Praveen.
Thank you for your opinion.
we meet 1 and 2. but not sure 3
we had opened case to TAC.
they said they refreshed DCA service, and problem solved.
Praveen Anand
Hi Park,
There are some prerequisites for vAnalytics.
1) you need to have DNA-Advantage licence to enable vAnalytics
2) if so, vManage should have reachablity to the internet to sent the data to vAnalytics.
3) Tac needs to create an vAnalytics instance access for you
please refer the below link for how to deploy the same.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/vAnalytics/vAnalytics-book/vAnalytics.html#Cisco_Concept.dita_2ccf4602-da35-4dfa-9723-0879abfd7151
- Praveen Anand
Hi Praveen.
