vEdge CLI Output Layout
fatalXerror
Level 5
Level 5
Hi Guys,
I have two vEdges running same OS version however, I noticed that the CLI output layout of each vEdge are different. For example, the "show tunnel statistics" command, my vEdge01 is showing it in a tabular format but in my vEdge02 it shows it in a list format. Another one is the "show interface" command, the vEdge01 shows it in tabular format but the vEdge02 shows it in a list format.
Do you know how can I make the vEdge02 to be in tabular format as well the same as vEdge01? It is much easier to check if it is in tabular format.
svemulap@cisco.com
Is both the vEdges have the same terminal type ?
The display might not be fitting in the tab format. Hence showing it in list format.
Do 'show tunnel statistics | tab' { pipe it to tab } to see in tabular format.
