vEdge SNMP
fakrulalam
I have enabled SNMP in vEdge device; but SNMP query is not working from the NMS. I have tried with snmpwalk/snmpget but no response. SNMP config:
snmp
no shutdown
view v2
oid 1.3.6.1
oid 1.3.6.1.*
community read-only
view v2
authorization read-only
group v2 auth-priv
view v2
user snmp
auth md5
auth-password $8$gWGxXKchTONylD1IAvgkxUunkBiBQ54EtREVDmRUO7E=
priv aes-cfb-128
priv-password $8$UrhE2PeFJd+Bl/OnSwYqR76JKs71PQV3gmqt/0XMZ+w=
group v2
Anything missing?
Hi Fakrul,
VPN512 would be the most recommended segment to handle network management traffic across the fabric.
I can think of one solution, still you have to get a shot to make sure if it works:
You can create a new IPv4 ACL (consider ingress for the transport interface) to permit SNMP traffic, then apply that to the ingress direction as per below:
Feature Templates: VPN Interface Ethernet | ACL/QOS | Ingress ACL - IPv4
Please try the above workaround and let me know if it works.
Ehsan
RohitRaj03827
Hello fakrulalam,
Please use following commands for SNMP configuration for vEdge:-
snmp
no shutdown
view v2
oid 1.3.6.1
community private
view v2
trap target vpn 0 10.0.1.1 16662
!(please udp port number 16662 for snmp configuration of viptela devices ) (I have targeted vpn 0, however you can target vpn 1 as well as , depends upon your requirements, 10.0.1.1= snmp server address)
group-name Cisco
community-name private
trap group test
all
level critical major minor
exit
exit
Please mark this post solve and hit on helpful button, if this post has answered your query.
Regards.
Rohit Raj
Rohit Raj
elesani
How your NMS reach out to Edge devices? Is it using VPN512 - or a configured management VPN or are you using Transport VPN?
If using Transport VPN, be mindful of Implicit ACL applied as part of Transport Interface nature in Cisco SD-WAN fabric.
Hi Elesani,
Yes, I am trying VPN 0 (Transport VPN). VPN512 works fine. Is there any option to allow SNMP in the transport interface?
Fakrul.
Hi Fakrul,
Ehsan
