Vedge Time Synch Issue
ssg14
I have a very strange issue , Vedge is registered on Vmanage as below (Only CLI at this stage and no template)
I have configured ntp on the vedge and vedge has also internet access but cannot synch(time cannot be manually set too)
Anybody faced this issue before? There is no way to debug vedge to check if any packet even comin out or not.
The issue is when i try to assign template it fails and i suspect the NTP is the issue while everything else is fine. The Vmanage and Vedge clock are 1hr apart.
Samy
 You have configured ntp on vEdge but they are able to reach the NTP server?  Looks like not.
-If I helped you somehow, please, rate it as useful.-
@Flavio Miranda wrote:
Hi Flavio,
I have already put a screenshot of Vedge pinging the NTP server.
There is no reachability issue between Vedge and the time server.
Samy
