vEdge to vBond control connection failing with error CRTVERFL
jay3
Hi Guys,
May you kindly assist me in troubleshooting the control connection between my vEdge and vBond. It seems they are failing to verify each other's certificates.I am using vManage signed certificates for my WAN edge devices and I have loaded the vManage root certificate into my vEdge root CA store.
H Elesani,
Thanks for your response. I managed to figure it out.For some reason, the vEdge was failing to verify the vBond certificate although they were both signed by the same Enterprise root CA. To ensure they were using the exact same root-cert-chain, I opened a vshell and copied the master.root.crt file(which had my root CA installed) from vBond to /home/admin on the vEdge and installed it and everything came up fine!
5 Replies 5
elesani
You need to sync the new authorised list of devices/controllers from vManage to vBond and vSmart controllers once you introduced any new Edge device or even new Control Plane controller.
Can you confirm bellow:
From vManage go to Configuration|Certificates
if "Send to Controller" button colour is in red, means that you haven't synced vManage with other controllers including vBond.
H Elesani,
millenski
can you provide guidance from how you copied the root CA. I have the same problem now with 2x vedge2000 failed to establish control connections to vbond.
                  LOCAL               REMOTE
STATE         ERROR              ERROR
tear_down CRTVERFL NOERR
Thanks.
Kind regards
Milen
For the Benefit of all, SCP worked better than cut and paste,
Login to your vedge ( mine was a vedge 5k)
vshell
cd /home/admin
scp admin@<vbond-ip>:/home/admin/master_root.crt .
Ps : There is a dot at the end of the command for current directory, I did a copy from vbond to local directory.
Few days later with my vE-2000 running old 17.1 (to match 20.6 Cisco PKI) I had to do the same, thanks for your quick hints and for completeness of information (like Stack Overflow world teaches us) I add:
request root-cert-chain install /home/admin/master_root.crt
