viptela Cisco SDWAN Lab Controllers
hamdialhola94
I have SDWAN lab (Vmanage, vsmart, vbond) after the initial configuration I installed certificates on all controllers, but I have a problem, when do  show control connections , nothing was shown. nd when do show orchestrator connections on Vbond nothing shown, don't have an idea about this issue, indeed to help to set up the lab.
Thanks.
4 Accepted Solutions
Torbjørn
I suspect that you might be missing tunnel-interface configuration. Can you post the configurations of the controllers?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
balaji.bandi
As you mentioned the Lab is this virtual Lab ?
try reload all the device in order and check ?  turn off all, start vmanage, vbond, vsmart
have similar lab works as expected, i had faced same issue reboot the device has fixed the issue : (if the configuration correct)
https://www.balajibandi.com/?p=2028
BB
share show control local-properties from vmanage/vsmart and show orchestrator local-properties from vbond.
HTH,
Hi, im reconfiguring the controllers , now only on bond is empty shown
just vbond , and others (manage and smart are ok)
can you see:
vBond# show control connections
vBond#
9 Replies 9
Torbjørn
vManage1# show running-config
system
host-name vManage1
system-ip 1.1.255.1
site-id 255
admin-tech-on-failure
sp-organization-name hamdibcd
clock timezone Africa/Tripoli
vbond 10.46.46.102
aaa
auth-order local radius tacacs
usergroup basic
task system read write
task interface read write
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
usergroup tenantadmin
user admin
password
$6$bYvLnnnqp9iaGrb6$wO2y0Aezmq2ZFPVY3qsi09FLzSsER7SKizh3OsT03dSYt2YQRZEMq/UYSqr53lwWG9YnaZm84VPpNUT6JgTLT/
user ciscotacro
description CiscoTACReadOnly
group operator
status enabled
user ciscotacrw
description CiscoTACReadWrite
group netadmin
status enabled
logging
disk
enable
ntp
server 10.46.46.111
version 4
prefer
exit
vpn 0
interface eth1
ip address 10.46.46.101/24
tunnel-interface
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service netconf
allow-service ntp
no allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 10.46.46.111
vpn 512
interface eth0
ip address 10.46.46.201/24
no shutdown
vSmart# show running-config
system
host-name vSmart
system-ip 1.1.255.3
site-id 255
vbond 10.46.46.102
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password
$6$BGJOalKeyVXf7vDc$bfbpp25WsTtUFKsRh6r3fafu85ZEs28iOqoLIvvyGyXzi7cHnWMOfp/n.5ckbBjgOHPTQzzTIr9WhhGemWFXd/
user ciscotacro
group operator
status enabled
user ciscotacrw
group netadmin
status enabled
logging
disk
enable
ntp
server 10.46.46.111
version 4
prefer
exit
omp
no shutdown
graceful-restart
vpn 0
interface eth1
ip address 10.46.46.103/24
tunnel-interface
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service stun
no shutdown
vpn 512
interface eth0
ip address 10.46.46.203/24
no shutdown
vbond# show running-config
system
host-name vbond
system-ip 1.1.255.2
site-id 255
no route-consistency-check
vbond 10.46.46.102 local
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password
$6$HYGq1VGWzvQkyH1I$jY1rUg/tvWQQgF4zNoDs9nNqlFsFgS8WxVXUBIFRCH6CJE0H.pnNDheOVwD/WIilAYVrBIbrLtyN0TbnhiA730
user ciscotacro
group operator
status enabled
user ciscotacrw
group netadmin
status enabled
logging
disk
enable
ntp
server 10.46.46.111
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
authentication-type ah-sha1-hmac sha1-hmac
vpn 0
interface ge0/0
ip address 10.46.46.102/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
no allow-service ospf
allow-service https
no shutdown
vpn 512
interface eth0
ip address 10.46.46.202/24
ipv6 dhcp-client
no shutdown
Note: I reconfigure the controllers but when I do (Show Control
Connections) shown vbond as: vbond dtls 0.0.0.0
What is wrong?
Please give me what I must configure the tunnel interface on all controllers,.
i may have lost this thread - what is the issue ? you not able to see vbond show connections ?
BB
balaji.bandi
BB
can you see:
vBond#
HTH,
vManage1# show control local-properties
personality vmanage
root-ca-chain-status Installed
certificate-status Installed
certificate-validity Valid
certificate-not-valid-before Mar 19 20:09:36 2024 GMT
certificate-not-valid-after Sep 09 20:09:36 2029 GMT
dns-name 10.46.46.102
site-id 255
domain-id 0
protocol dtls
tls-port 23456
system-ip 1.1.255.1
chassis-num/unique-id 93f108a8-bd4d-4e19-a291-dd6e105df4ba
serial-num D33A80FE42052F4A
subject-serial-num N/A
cloud-hosted no
token -NA-
retry-interval 0:00:00:16
no-activity-exp-interval 0:00:00:20
dns-cache-ttl 0:00:02:00
port-hopped FALSE
time-since-last-port-hop 0:00:00:00
cdb-locked false
number-vbond-peers 1
INDEX IP PORT
0 10.46.46.102 12346
number-active-wan-interfaces 4
PUBLIC PUBLIC PRIVATE
PRIVATE PRIVATE
LAST
INSTANCE INTERFACE IPv4 PORT IPv4 IPv6
PORT VS/VM COLOR STATE
CONNECTION
0 eth1 10.46.46.101 12346 10.46.46.101 ::
12346 1/0 default up 0:00:00:07
1 eth1 10.46.46.101 12446 10.46.46.101 ::
12446 0/0 default up 0:00:00:08
2 eth1 10.46.46.101 12546 10.46.46.101 ::
12546 0/0 default up 0:00:00:09
3 eth1 10.46.46.101 12646 10.46.46.101 ::
12646 0/0 default up 0:00:00:08
vSmart# show control local-properties
personality vsmart
certificate-not-valid-before Mar 19 20:23:01 2024 GMT
certificate-not-valid-after Sep 09 20:23:01 2029 GMT
site-id 255
domain-id 1
protocol dtls
tls-port 23456
system-ip 1.1.255.3
chassis-num/unique-id 15cc1f84-2ba7-4a9b-839c-4daf4d96489f
serial-num D33A80FE42052F4C
token -NA-
retry-interval 0:00:00:19
port-hopped FALSE
cdb-locked false
INDEX IP PORT
number-active-wan-interfaces 2
PRIVATE PRIVATE
LAST
CONNECTION
0 eth1 10.46.46.103 12346 10.46.46.103 ::
12346 0/1 default up 0:00:00:10
1 eth1 10.46.46.103 12446 10.46.46.103 ::
12446 0/0 default up 0:00:00:11
vBond# show orchestrator local-properties
personality vbond
system-ip 1.1.255.2
certificate-not-valid-before Mar 19 20:17:23 2024 GMT
certificate-not-valid-after Sep 09 20:17:23 2029 GMT
chassis-num/unique-id 3b650ba7-7049-487d-a9e2-9bbf3dcc8354
serial-num D33A80FE42052F4B
number-active-wan-interfaces 1
protocol dtls
INSTANCE INDEX PORT VSMARTS VMANAGES STATE
0 0 12346 2 4 up
I confused, did you solve the problem?
If not, clear control connection history by "clear control connection-history" wait for 5minutes and then provide show control connection-history from all controllers (for vbond use orchestrator keyword)
HTH,
