viptela hardware security certificate expired issue
dsalustri
My customer has VEDGE routers deployed globally I was made aware of an issue with the routers losing connection with the control plane, what is going on with this issue, is there a fix coming and if so when?
10 Replies 10
svemulap@cisco.com
Can you verify this is only affecting the versions listed, if we were to upgrade to let's say 20.10.1 - would this be resolved?
It is not applicable on 20.10.x
Last supported image on the vEdge platform (vE2K) is 20.9.x
Ok, so it 20.9 affected?
Yes.
SirMacBeth
Please refer to this document
CSCwf28118 : Bug Search Tool (cisco.com)
Short answer - NO.
Long answer - as the issue is with a certificate on the TPM chip, wouldnt matter what version you upgrade/downgrade to, it would still be affected.  Cisco are working on a resolution and should have something out very soon
Umar.Ally
Feedback from Cisco is very unclear they mention specific IOS versions as being unaffected however this is not the case:
