08-16-2020 11:22 PM
Hi Guys,
has anyone seen this issue on viptela cloud vedges init-in-gr. this is on 19.2.2 and 19.2.3
BR2-R1# show omp peers
R -> routes received
I -> routes installed
S -> routes sent
DOMAIN OVERLAY SITE
PEER TYPE ID ID ID STATE UPTIME R/I/S
10.255.255.1 vsmart 1 1 1 init-in-gr 0/0/0
04-26-2021 02:47 PM
The init-in-gr status shows your wan edge is in omp graceful restart state. Check the control connections to your controllers.
Lei Tian
05-02-2021 05:58 AM
when router loses control connection to vSmart, it still uses last information received from vsmart. In this case, OMP state for vsmart is "init-in-gr". This means, router has last information from respective device in OMP table. Default time is 12h, as I remember. If router cant re-establish control connection with vsmart, it will declare received routes from peer as invalid.
HTH,
