viptela vBond template issue
osman.elhanafy
Dears,
i faced an issue while i was trying to attach device template to vBond controller, pleasefind below the error
Server error: Error on line 47: unknown element: ipv6-advertise in /ncs:devices/ncs:device[ncs:name='vip_internal_temp_device_88f6c76b-0fb0-4e14-8c95-5e5d56320f5f']/ncs:config/viptela-omp:omp/viptela-omp:ipv6-advertise
thanks,
Martin Kyrc
Level 3
Level 3
I had the same issue with vEdge but I think it should be the same problem. My vManage version is 18.4.0. After some troubleshooting I have solution.
Problem description (im my case):
  • Issue is connected with OMP default configuration in Device Template (TPL) configuration. By default is IPv6 enabled.
  • when you apply device template with no IPv6 network configuration, you get error message
Solution (in my case):
  • create own "omp feature template" (copy it from default template "Factory_Default_vEdge_OMP_ipv46_Template")
  • disable IPv6 in your new template
  • attach customized feature TPL to your device TPL
Let us know if it's working for you,
Martin
ekhabaro
Can you please let me know which version of vManage are you using?
Martin Kyrc
Level 3
Level 3
Martin
