Viptela vManage certificate issue
osman.elhanafy
 Dears,
i have got an error when i try to install the certificate
12-Feb-2019 15:25:58 EET] Install Certificate, on device 95c654e1-8465-480d-9749-ab37293bb89f, started by user "osman" from IP address "192.168.10.153"
[12-Feb-2019 15:25:59 EET] Pushing serial list to vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
[12-Feb-2019 15:25:59 EET] Started processing serial list file on vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
[12-Feb-2019 15:26:00 EET] Completed processing serial list file on vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
[12-Feb-2019 15:26:00 EET] Done - Push vSmart List for vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
[12-Feb-2019 15:26:00 EET] Updated controllers with new certificate serial number of vManage-95c654e1-8465-480d-9749-ab37293bb89f
[12-Feb-2019 15:26:01 EET] Failed to process device request -
Error type : application
Error tag : operation-failed
Error Message : log : Error: root-ca-chain unable to validate the certificate... Aborting !
Error info : <error-info>
  <bad-element>install</bad-element>
</error-info>
[12-Feb-2019 15:26:01 EET] Pushing serial list to vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
[12-Feb-2019 15:26:01 EET] Started processing serial list file on vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
[12-Feb-2019 15:26:02 EET] Completed processing serial list file on vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
[12-Feb-2019 15:26:02 EET] Done - Push vSmart List for vManage-95c654e1-8465-480d-9749-ab37293bb89f (Vmanage1)
 i use enterprise root certificate and i have installed the CA certificate but still got this error.
Please any one can help me ??
thanks
I have solved the issue by install it through the command line.
the error type application so i tried with another browser.
6 Replies 6
ekhabaro
Do you have root-cert-chain installed?
How did you install the certificate via the command line?
It's better to give us the solution with prop, script, notes, link.. etc at least something
It works for me
request root-cert-chain install /home/admin/ROOTCA.pem
it is working  for me
