09-06-2019 06:15 AM
Hi All,
I am trying configure vManage cluster, i have two vManage , one vManage already running and i am trying to add new vManage into cluster. i have followed the below:-
sd-wan doc links. still not working
i went to Administration under that cluster management, under service configuration tab :-
clicked on add vManage , it gave me to enter the new vManage ip address and all, have done. says completed, still the second vmanage is not showing,
kindly help me if i am missing anything.
aspa
09-08-2019 08:04 AM
Which interface IP address are you using in vManage for clustering?
Srikanth
09-22-2019 11:23 PM
I am using three interfaces:-
eth0 ---- for VPN 0
eth1--- for OOB(GUI access)
eth2-- for cluster management.
01-24-2020 04:33 AM
Hi There
Are you implementing a vManage Cluster of 2 nodes? Are both vManage in the same L2 network?
01-24-2020 05:25 AM
That is already resolved.
01-24-2020 06:32 AM
Can you tell me which vManage version you are using?
01-24-2020 11:20 PM
08-17-2020 07:18 PM
03-03-2020 12:53 AM
Hi Rohit,
Can You Tell More about the workflow you used for vManage clustering?
best regards,
ehsan
03-09-2020 01:51 AM
09-13-2020 02:06 AM
Hi Rohit,
Yes, I Mean the steps for vManage Cluster Configuration.
Best Regards,
Ehsan
