vManage installation in Active/Standby state
csdinesh18
Could someone please help with the steps to configure vManage in Standby mode? we're using the version 19.2.3
Hi Dinesh ,
Have you got solution .
I am looking for same to deploy
The steps are available in the below link.
We did it successfully.
https://www.cisco.com/c/dam/en/us/td/docs/routers/sdwan/knowledge-base/disaster_recovery_technote.pdf
Hi Dinesh ,
I checked this document but was not able to succeed , if you can connect with me once would be great helpful .
in this document it is given at a time a DR we need to upload backup from primary Vmanage i understood this .
my Confussion is do we need to add any cluster or disaster recover for Vmanages .
2. Verify that all services are running on the standby vManage NMS. From the CLI, use the request nms all status command.
3. On the standby vManage(s), navigate to Configuration ► Devices ► Controllers. Verify that the page displays all vManage(s)
for active and standby systems.
iam able to see only one vmanage in standby vmanage .
If your comfortable can we connect any remote or  phone .
