vManage interface config error message - values are not unique: eth0
kjp1231
When trying to commit the interface configuration I get the following message -
Aborted: values are not unique: eth0
'vpn 0 interface eth0 if-name'
'vpn512 interface eth0 if-name'
My config is -
vpn0
 Interface eth1
  Ip address 10.20.129.151/24
  no shutdown
 Ip route 0.0.0.0/0 10.20.129.1
vpn 512
 Interface eth0
  Ip address 10.20.64151/24
  no shutdown
 Ip route 0.0.0.0/0 10.20.64.1
gneslim
The error message you're getting seems to signal that you're trying to configure interface eth0 in both VPN0 and VPN512. That is not an acceptable configuration because a layer 3 interface can only be placed in one VPN.
Running config doesn't look fine also:
vpn 512
 Interface eth0
  no shutdown
Your IP address is invalid.
ccie.22939
You have to "no vpn 0 interface eth0" first and commit. After that, your eth0 will remove from [vpn 0] section and shutdown.
Mohamed Alhenawy
Please Follow Those
vpn0
no Interface eth0
Commit and quite
Config
Vpn0
Interface eth1
no shutdown
commit and quite
vpn 512
Interface eth0
no shutdown
