vManage size is bigger and bigger
interfacedy
Hi vManage and vbond/vsmart are installed in eve-ng/linux base, which is installed on ESXi. Their size(vManage 2.9G) in eve-ng is less than 4GB including some other routers. but the size is becoming bigger and bigger after installation and run. The size increasing is quick and too much. now its almost 60GB to full. Please see the below. I am not sure if this is vManage issue or something else. I tried to install it several times. Each time the size is increase too much. Anyone can share some experience or provide some suggestion? Thank you very much!
interfacedy
resolved after changing ios
interfacedy
