vManage webhook alert
I have configured notification based on the following document and enabled webhook:
https://sdwan-docs.cisco.com/Product_Documentation/vManage_How-Tos/Operation/Configure_Email_Notifications_for_Alarms
But I am not receiving any wehbook notification. I have tried calling the webhook manually (using Postman) and it's working fine. Is there anything else I can check?
Fakrul Alam
kjawaid
Hi Fakrul,
Possibly because you are using https whereas the document is configuring http wit a username and password.
sy-trinh
I having the same issue, vmanage /var/log/nms/vmanage-server.log showing "Response status code after sending webhook: 400"
I am using vManage version 20.12.3.1
Looks like wrong API call executed, HTTP code 400 returned by webhook gw. Did you try Postman/curl/wget or similar tool to execute it manually and verify its correctness?
